Einleitung
This guide will demonstrate how to replace the keyboard for the Dell Inspiron 15-7559. This may be necessary if you are unable to use the keyboard.
Was du brauchst
Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
Once the latch is raised, lift the ribbon cable up and out of the latch.
Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
8 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
How to put it back
Do the steps in reverse order, like it says at the end of the tutorial
