Einleitung
Make sure to disconnect the battery before replacing the hard drive.
Was du brauchst
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
Remove the cable from the motherboard that is attached to the Hard Drive.
Use your fingers or the plastic opening tools to gently pull up on the clip, freeing the cable.
Fast fertig!
Abschluss
