Zum Hauptinhalt wechseln
Dell Inspiron 15-7567 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15-7567 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 2 Dell Inspiron 15-7567 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 2 von 2
    • Remove the four 5mm screws with a Phillips #1 screwdriver.
  8. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Remove the cable from the motherboard that is attached to the Hard Drive.
    • Use your fingers or the plastic opening tools to gently pull up on the clip, freeing the cable.
  9. Dell Inspiron 15-7567 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Lift and remove Hard Drive.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 1,265
