Einleitung
This is an easy component to replace and only need a screwdriver to complete. This may be replaced if you get a blue screen before the laptop starts.
Was du brauchst
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
Release the two clips on the left and right side, by pushing outward on the side towards you.
The RAM strip will extend out. Pull towards you at a slight angle.
