Einleitung
This may be needed if your touchpad is not working as it usually does.
Was du brauchst
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
Remove the clip holding the power cord on the Touch Pad by using tweezers, your fingers, or iFixit removing tools to gently pull up on the clip.
This should release the power cord as shown.
Remove the four 3mm screws using a Phillips #1 screwdriver in the locations shown.
2 weitere Personen haben diese Anleitung absolviert.
