Einleitung
The following guide will demonstrate how to replace the wireless card in the Dell Inspiron 15-7567. You may need to replace if your wireless connection is bad.
Was du brauchst
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
Pinch the clips on the left and right side while pulling on the cord at the same time.
Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
Detach the black and white wires connected to the card by gently lifting up on the wires.
