Einleitung
If your display has stopped working or has been cracked, follow this guide to replace it.
Was du brauchst
Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
After removing the screws, remove the back cover using a plastic or metal spudger.
Unscrew screws on gray clamps. One screw is located near the fan, one is located near the RAM.
Remove all parts connected to the hinges.
Snap off the hinges.
