Zum Hauptinhalt wechseln
Einleitung
In this guide, we will be showing you how to remove and replace the Memory Module.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  2. Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Remove the memory module from the memory-module slot.
    • Remove the memory module from the memory-module slot.
  5. Lift the Mylar to access the memory-module slot.
    • Lift the Mylar to access the memory-module slot.
  6. Align the notch on the NEW memory module with the tab on the memory-module slot. Align the notch on the NEW memory module with the tab on the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  7. Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Ziellinie
Terrence15
70.858 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
930 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 97
