Einleitung
This guide will show you how to remove the memory from your device.
Was du brauchst
Place the laptop facedown with the battery facing you.
Push the switch above the battery to the right and hold it in that position.
Lift the battery using the grip on the top and remove it from its socket.
Pull the two metal clips holding down the card apart.
Lift and pull out the card.
Fast fertig!
Abschluss
