Zum Hauptinhalt wechseln
Dell Inspiron 1520 Display Assembly Replacement
Was du brauchst
    • Follow the instructions in Before You Begin.
    • Close the display and turn the computer over.
  1. Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: Schritt 2, Bild 1 von 2 Dell Inspiron 1520 Display Assembly Replacement, Loosen the Screws: Schritt 2, Bild 2 von 2
    • Loosen the two captive screws that secure the Mini Card compartment cover, then remove the cover and set it aside.
  2. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: Schritt 3, Bild 1 von 2 Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: Schritt 3, Bild 2 von 2
    • Remove the two M2.5 x 8-mm screws from the bottom of the computer.
  3. Dell Inspiron 1520 Display Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the two M2.5 x 8-mm screws from the back of the computer.
  4. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Display Cable: Schritt 5, Bild 1 von 1
    • Loosen the captive grounding screw, then disconnect the display cable from the display cable connector on the system board.
  5. Dell Inspiron 1520 Display Assembly Replacement, Disconnect the Connector: Schritt 6, Bild 1 von 1
    • Disconnect the camera/microphone cable from the camera/microphone cable connector on the system board.
  6. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: Schritt 7, Bild 1 von 2 Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Cable: Schritt 7, Bild 2 von 2
    • Lift the display cable and antenna cables from beneath the tabs on the palm rest.
    • NOTICE: Ensure that the display cable and the antenna cables do not get caught beneath the plastic tabs on the palm rest.
  7. Dell Inspiron 1520 Display Assembly Replacement, Lifting the Display Assembly: Schritt 8, Bild 1 von 1
    • Lift the display assembly out of the computer.
    • Align the display hinges with the holes in the base of the computer, then lower the display into place.
  8. Dell Inspiron 1520 Display Assembly Replacement, Sliding the Antenna Cables: Schritt 10, Bild 1 von 1
    • Slide the antenna cables through the hole in the palm rest and the base of the computer.
    • NOTICE: Ensure that the display cable and antenna cables are properly routed and secured beneath the plastic tabs on the palm rest.
  9. Dell Inspiron 1520 Display Assembly Replacement, Routing the Display Cable: Schritt 11, Bild 1 von 1
    • Route the display cable and antenna cables beneath the plastic tabs on the palm rest.
  10. Dell Inspiron 1520 Display Assembly Replacement, Connecting the Cables: Schritt 12, Bild 1 von 1
    • Connect the camera/microphone cable to the camera/microphone cable connector on the system board.
  11. Dell Inspiron 1520 Display Assembly Replacement, Connect the Display Cable: Schritt 13, Bild 1 von 1
    • Connect the display cable to the display cable connector on the system board.
  12. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screw: Schritt 14, Bild 1 von 1
    • Replace and tighten the captive grounding screw.
  13. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: Schritt 15, Bild 1 von 1
    • Replace the two M2.5 x 8-mm screws on the back of the computer.
  14. Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: Schritt 17, Bild 1 von 2 Dell Inspiron 1520 Display Assembly Replacement, Replace the Screws: Schritt 17, Bild 2 von 2
    • Replace the two M2.5 x 8-mm screws on the bottom of the computer.
    • Replace the Mini Card compartment cover and tighten the screws.
Ziellinie
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 415
