Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Was du brauchst
Turn the computer over.
Remove the four M3 x 3-mm screws that secure the hard drive.
Remove the two M3 x 3-mm screws from each side of the hard drive bezel, then pull to separate the bezel from the hard drive.
Slide the hard drive bezel onto the NEW hard drive, then tighten the two M3 x 3-mm screws to secure the bezel to the drive.
Slide the hard drive into the hard drive bay until the drive is fully seated.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
