Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to prepare the computer for the removal of the panel underneath the keyboard.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Rotate the laptop so its bottom is facing up.
    • Rotate the laptop so its bottom is facing up.
  2. Du brauchst kein Neues.
    Take $10 off $50 with
    SKIPANDSAVE10
    Jetzt speichern
    SKIPANDSAVE10
    Jetzt speichern
  3. Identify the lock mechanisms holding the battery in place. Slide each button outward with your fingers to disengage the battery. Pull the battery off with your hand to separate it from the laptop.
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  4. Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop. Remove the thirteen indicated screws with a Phillips #1 screwdriver.
    • Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
    • Remove the thirteen indicated screws with a Phillips #1 screwdriver.
    • With the screws removed you can now remove the panel underneath keyboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Erik Sanchez
21 Reputation
1 Anleitung geschrieben
Cal Poly, Team 15-47, Forte Fall 2012 Mitglied von Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 963
