Zum Hauptinhalt wechseln
Dell Inspiron 1521 DVD Drive Replacement
Was du brauchst
  1. Dell Inspiron 1521 DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 DVD Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 1521 DVD Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 1521 DVD Drive Replacement: Schritt 2, Bild 3 von 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: Schritt 3, Bild 1 von 2 Dell Inspiron 1521 DVD Drive Replacement, DVD Drive: Schritt 3, Bild 2 von 2
    • Locate the 4 mm Phillips #1 screw next to the white padlock image that holds the DVD drive in place.
    • Remove this screw with a Phillips #1 screwdriver.
  4. Dell Inspiron 1521 DVD Drive Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 1521 DVD Drive Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 1521 DVD Drive Replacement: Schritt 4, Bild 3 von 3
    • Use a plastic opener tool to carefully pry the DVD drive out of its pocket on the side of the laptop.
    • Once sticking out, pull the DVD drive the rest of the way out with your hand.
Abschluss
Cal Poly, Team 15-47, Forte Fall 2012 Mitglied von Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,012
