Einleitung
Use this guide to help you replace the RAM in a Dell Inspiron 1525.
Was du brauchst
Slide the battery release switch away from the lock symbol until you hear the battery click.
Slide the battery towards the back of the laptop until it comes free.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Push the white tabs on either side of the RAM chip outward. The chip should pop up a little.
Carefully remove the RAM chip by pulling it out at a slight vertical angle.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
