Zum Hauptinhalt wechseln
Dell Inspiron 1526 Heat Sink Replacement
Was du brauchst
  1. Dell Inspiron 1526 Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 1526 Heat Sink Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 1526 Heat Sink Replacement, Battery: Schritt 1, Bild 3 von 3
    • Slide the unlock button to the left to release the battery.
    • Slide the battery away from the laptop to remove.
    • The unlock button is located on the bottom of the laptop.
  2. Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: Schritt 2, Bild 1 von 2 Dell Inspiron 1526 Heat Sink Replacement, Heat Sink: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the eight 3mm screws from the rear casing of the laptop.
  3. Dell Inspiron 1526 Heat Sink Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 1526 Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Loosen the five captive Phillips #0 screws from the heat sink.
    • Lift the heat sink from the motherboard.
  4. Dell Inspiron 1526 Heat Sink Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 1526 Heat Sink Replacement: Schritt 4, Bild 2 von 2
    • Apply a pea-sized amount of new thermal paste to the CPU and GPU.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 158
