Einleitung
This guide may be utilized if you are having overheating problems with your laptop. The CPU Heat Sink is responsible for keeping the CPU cool and monitoring its current state.
Was du brauchst
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
