Zum Hauptinhalt wechseln
Dell Inspiron 1545 Computer Processing Unit Replacement
Was du brauchst
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: Schritt 4, Bild 1 von 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: Schritt 6, Bild 1 von 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 7, Bild 1 von 1
    • Pull up on the Heat Sink unit to remove it.
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: Schritt 8, Bild 1 von 1
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: Schritt 9, Bild 1 von 1
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Nathan Lemay
3.052 Reputation
15 Anleitungen geschrieben
Cal Poly, Team 9-14, Regan Spring 2014 Mitglied von Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 2,624
