Einleitung
This guide will teach you how to remove components all the way down to the CPU fan.
Was du brauchst
Locate battery latch on the bottom of the computer and slide to the right.
While holding battery latch, pull battery away from device.
With the J0 screwdriver bit, loosen all the screws from the backing opposite of battery.
Remove the covering.
Gently pull back the small clips along the side of each stick of RAM.
Gently lift the RAM upwards so the RAM is now angled.
Pull the RAM away from the device.
Repeat steps for second stick of RAM
Unscrew the four screws holding in the hard drive.
Slide the hard drive towards and to the left to unplug it.
Pry the hard drive upwards and pull away from device.
With the J0 screwdriver remove the 11 screws on the bottom of the computer.
Locate the CD drive at the left side when computer is flipped over.
Pry CD drive away from device gently.
Using the blue plastic opening tool, start prying in the space between the screen and the keyboard.
Remove black cover from the keyboard.
Remove the four screws on the top of the keyboard.
Press down on the tabs on each side of the keyboard to free it.
Remove the keyboard by pulling the board towards the screen and up.
Flip the latch on the computer connecting the ribbon cable to the keyboard.
Slide the keyboard ribbon cable out.
Remove the five screws that were underneath the keyboard.
Lift black and white wire connections away from the device.
Slide wires through the hole to the top of the keyboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using the J0 screwdriver bit, remove two 7mm screws holding fan in place.
With tweezers, gently pull cable connecting fan to board.
Gently tilt fan upwards and remove.
5 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
It's a nice guide to disassemble the notebook correctly, but I would like to add more precise pictures at some steps. At step 9 for example you wrote to lift up the cables for sliding wires through a hole in the couvering plate. Here it was useful to show with a coloured circle where to locate this. In the last step you added a wrong picture. The second image shows the wireless card and how to disconnect it's cables instead the fan's connector. But apart from that this guide was useful (sorry for possible language mistakes) :-)
Now i’m assuming that this is because my computer has been used quite a bit, but in step 8, my ribbon cable fell apart. it is currently held together with electrical tape and prayers. so if anyone would want to not have that happen, I suggest removing the power button and tucking it away instead.
