Zum Hauptinhalt wechseln
Dell Inspiron 1564 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 1564 Hard Drive Replacement, Remove Battery: Schritt 1, Bild 2 von 2
    • Locate battery latch on bottom of computer and slide to right.
    • While holding battery latch, pull the battery away from device and the battery will come free.
  2. Dell Inspiron 1564 Hard Drive Replacement, Remove Bottom Cover Screws: Schritt 2, Bild 1 von 1
    • With a J0 screwdriver bit, loosen all screws from the backing above the battery latch and remove the covering.
  3. Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: Schritt 3, Bild 1 von 2 Dell Inspiron 1564 Hard Drive Replacement, Hard Drive Removal: Schritt 3, Bild 2 von 2
    • Locate the three 4mm screws securing the hard drive and unscrew them with a J0 screwdriver.
    • Slide the hard drive to the left to unplug the SATA data and SATA power cables, then gently pry upwards and pull the drive away from device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 2,000
