Einleitung
If your Dell Inspiron 1564 Laptop is not holding a charge or will not turn on, a battery replacement may be the solution.
Was du brauchst
Turn the laptop off by holding down the silver power button in the upper left corner until all the lights turn off.
Close the cover of the laptop and turn the laptop over so the the bottom is facing up.
Locate the release latch.
Locate the battery on the bottom of the laptop.
Slide the battery release latch to the right and hold it.
With your other hand, pull the battery away from the laptop and release the latch.
- A new Dell Inspiron 1564 battery can be bought at www.laptopbatteryhq.com for about $30
6 weitere Nutzer:innen haben diese Anleitung absolviert.
