Zum Hauptinhalt wechseln
Dell Inspiron 1564 RAM Replacement
Was du brauchst
  1. Dell Inspiron 1564 RAM Replacement, RAM: Schritt 1, Bild 1 von 2 Dell Inspiron 1564 RAM Replacement, RAM: Schritt 1, Bild 2 von 2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: Schritt 2, Bild 1 von 1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 1564 RAM Replacement: Schritt 3, Bild 3 von 3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,006
