Zum Hauptinhalt wechseln
Dell Inspiron 15R 5520 Memory Module Replacement
Was du brauchst
  1. Dell Inspiron 15R 5520 Memory Module Replacement, Popping up the Memory Module: Schritt 1, Bild 1 von 2 Dell Inspiron 15R 5520 Memory Module Replacement, Popping up the Memory Module: Schritt 1, Bild 2 von 2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 15R 5520 Memory Module Replacement, Remove the Memory Module: Schritt 2, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 15R 5520 Memory Module Replacement, Align the Notch: Schritt 3, Bild 1 von 2 Dell Inspiron 15R 5520 Memory Module Replacement, Align the Notch: Schritt 3, Bild 2 von 2
    • Align the notch on the memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15R 5520 Memory Module Replacement, Sliding the Memory Module: Schritt 4, Bild 1 von 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ziellinie
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
2 Kommentare
I took apart my dell inspiron 15r 5520 to replace the Wi-Fi card & now the touchpad & buttons will not work. What might have I done wrong?
jdoerr9619 - Antwort
الكمبيوتر يصدر صفاره عدد اربعه ولا يقلع
النظام
نبيل العامري - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 311
