Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Peel the tape that secures the display cable to the system board.
Disconnect the display cable from the connectors on the system board.
Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
Remove the screws that secure the display assembly to the computer base.
Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
Replace the screws that secure the display assembly to the computer base.
Connect the wireless mini-card cables to the connectors on the wireless mini-card.
Connect the display cable to the connector on the system board.
Adhere the tape that secures the display cable to the system board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
