Zum Hauptinhalt wechseln
Dell Inspiron 15R Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 15R Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over and locate the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 15R Hard Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Place thumbs on each latch and push outwards.
    Frag FixBot
  3. Dell Inspiron 15R Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Push and slide the battery away from you.
    Frag FixBot
  4. Dell Inspiron 15R Hard Drive Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron 15R Hard Drive Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron 15R Hard Drive Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
    Frag FixBot
  5. Dell Inspiron 15R Hard Drive Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
    Frag FixBot
  6. Dell Inspiron 15R Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Turn the device around and open it up.
    Frag FixBot
  7. Dell Inspiron 15R Hard Drive Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Using your index finger, push down on the F1 and F7 keys.
    Frag FixBot
  8. Dell Inspiron 15R Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Using your index finger, push down on the x icon and Home keys.
    Frag FixBot
  9. Dell Inspiron 15R Hard Drive Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 9, Bild 3 von 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
    Frag FixBot
  10. Dell Inspiron 15R Hard Drive Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 10, Bild 2 von 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
    Frag FixBot
  11. Dell Inspiron 15R Hard Drive Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Carefully pull and turn the keyboard over.
    Frag FixBot
  12. Dell Inspiron 15R Hard Drive Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • Lift the black lever.
    Frag FixBot
  13. Dell Inspiron 15R Hard Drive Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 13, Bild 2 von 2
    • Remove the keyboard cable
    Frag FixBot
  14. Dell Inspiron 15R Hard Drive Replacement, Hard Drive: Schritt 14, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement, Hard Drive: Schritt 14, Bild 2 von 2
    • Turn laptop over and remove the bottom four screw covers outlined in red.
    • Then remove the three base screws.
    Frag FixBot
  15. Dell Inspiron 15R Hard Drive Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 15, Bild 2 von 2
    • Turn laptop over and open it. Locate and remove the five palm rest screws.
    Frag FixBot
  16. Dell Inspiron 15R Hard Drive Replacement: Schritt 16, Bild 1 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 16, Bild 2 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 16, Bild 3 von 3
    • Locate the palm rest cables. Lift the black levers and unplug the blue cables.
    Frag FixBot
  17. Dell Inspiron 15R Hard Drive Replacement: Schritt 17, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 17, Bild 2 von 2
    • Lift the palm rest until it snaps off.
    Frag FixBot
  18. Dell Inspiron 15R Hard Drive Replacement: Schritt 18, Bild 1 von 2 Dell Inspiron 15R Hard Drive Replacement: Schritt 18, Bild 2 von 2
    • Close cover and turn laptop over. Locate and remove the four hard drive screws.
    Frag FixBot
  19. Dell Inspiron 15R Hard Drive Replacement: Schritt 19, Bild 1 von 1
    Frag FixBot
  20. Dell Inspiron 15R Hard Drive Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 15R Hard Drive Replacement: Schritt 20, Bild 3 von 3
    • Lift and remove the hard drive.
    Frag FixBot
  21. Dell Inspiron 15R Hard Drive Replacement: Schritt 21, Bild 1 von 1
    • Remove the hard drive connector.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
San Diego State, Team 2-2, Sheppard Winter 2015 Mitglied von San Diego State, Team 2-2, Sheppard Winter 2015
SDSU-SHEPPARD-W15S2G2
2 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
Shoot! My Dell Inspiron 15R is different. Mine has an almost full length cover (11.6”) by 3” wide on the bottom. The hard drive and memory sticks are under that cover. I’m just not sure what else to remove to replace the drive with an SSD.
Adrian Kocurek - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 32
Insgesamt: 7,730
