Einleitung
If most keys on your keyboard are not working, this guide will help you replace the keyboard.
Was du brauchst
Locate the RAM compartment and the screw on the right hand side. Remove the cover.
Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
Locate the keyboard lining (between the black and silver).
Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
Eine weitere Person hat diese Anleitung absolviert.
