Zum Hauptinhalt wechseln
Dell Inspiron 15R Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 15R Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over and locate the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 15R Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Place thumbs on each latch and push outwards.
    Frag FixBot
  3. Dell Inspiron 15R Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Push and slide the battery away from you.
    Frag FixBot
  4. Dell Inspiron 15R Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron 15R Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron 15R Keyboard Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
    Frag FixBot
  5. Dell Inspiron 15R Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
    Frag FixBot
  6. Dell Inspiron 15R Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Turn the device around and open it up.
    Frag FixBot
  7. Dell Inspiron 15R Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Using your index finger, push down on the F1 and F7 keys.
    Frag FixBot
  8. Dell Inspiron 15R Keyboard Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Using your index finger, push down on the x icon and Home keys.
    Frag FixBot
  9. Dell Inspiron 15R Keyboard Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 15R Keyboard Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 15R Keyboard Replacement: Schritt 9, Bild 3 von 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
    Frag FixBot
  10. Dell Inspiron 15R Keyboard Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
    Frag FixBot
  11. Dell Inspiron 15R Keyboard Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 11, Bild 2 von 2
    • Carefully pull and turn the keyboard over.
    Frag FixBot
  12. Dell Inspiron 15R Keyboard Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 12, Bild 2 von 2
    • Lift the black lever.
    Frag FixBot
  13. Dell Inspiron 15R Keyboard Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 15R Keyboard Replacement: Schritt 13, Bild 2 von 2
    • Remove the keyboard cable
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
San Diego State, Team 2-2, Sheppard Winter 2015 Mitglied von San Diego State, Team 2-2, Sheppard Winter 2015
SDSU-SHEPPARD-W15S2G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 1,540
