Zum Hauptinhalt wechseln
Dell Inspiron 15R N5110 Display Assembly Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Dell Inspiron 15R N5110 Display Assembly Replacement, Peel the Tape: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Peel the tape that secures the display cable to the system board.
  2. Dell Inspiron 15R N5110 Display Assembly Replacement, Disconnect the Display Cable: Schritt 2, Bild 1 von 1
    • Disconnect the display cable from the connectors on the system board.
  3. Dell Inspiron 15R N5110 Display Assembly Replacement, Disconnect the Cables: Schritt 3, Bild 1 von 1
    • Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
  4. Dell Inspiron 15R N5110 Display Assembly Replacement, Move the Power-Adapter Cable: Schritt 4, Bild 1 von 1
    • Move aside the power adapter-port cable from the screws.
  5. Dell Inspiron 15R N5110 Display Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15R N5110 Display Assembly Replacement, Lifting the Display Assembly: Schritt 6, Bild 1 von 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 15R N5110 Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  8. Dell Inspiron 15R N5110 Display Assembly Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 15R N5110 Display Assembly Replacement, Connecting the Cables: Schritt 9, Bild 1 von 1
    • Connect the wireless mini-card cables to the connectors on the wireless mini-card.
  10. Dell Inspiron 15R N5110 Display Assembly Replacement, Connect the Display Cable: Schritt 10, Bild 1 von 1
    • Connect the display cable to the connector on the system board.
  11. Dell Inspiron 15R N5110 Display Assembly Replacement, Adhere the Tape: Schritt 11, Bild 1 von 1
    • Adhere the tape that secures the display cable to the system board.
Ziellinie
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 166
