Zum Hauptinhalt wechseln
Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement
Was du brauchst
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  1. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard Drive Assembly: Schritt 3, Bild 1 von 1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: Schritt 4, Bild 1 von 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Lifting the Hard-Drive Bracket: Schritt 6, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Align the Screw Holes: Schritt 7, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: Schritt 8, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Placing the Hard Drive Assembly: Schritt 9, Bild 1 von 1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: Schritt 10, Bild 1 von 1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R N5110 Hard-Drive Assembly Replacement, Replace the Screws: Schritt 11, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 640
