Einleitung
In this guide, we will be showing you how to remove and replace the Hard Drive.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
    • Using the pull-tab, slide the hard-drive assembly toward the back of the computer to disconnect the hard-drive assembly from the connector on the system board.
    • Lift the hard-drive assembly out of the computer base.
    • Remove the screws that secure the hard-drive bracket to the hard drive.
    • Lift the hard drive off the hard-drive bracket.
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
    • Replace the screws that secure the hard-drive bracket to the hard drive.
    • Place the hard-drive assembly on the computer base.
    • Using the pull-tab, slide the hard-drive assembly toward the front of the computer, to connect the hard-drive assembly to the connector on the system board.
    • Replace the screws that secure the hard-drive assembly to the computer base.
Ziellinie
Terrence15
Mitglied seit 18.12.2017
70.258 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 110
