Zum Hauptinhalt wechseln
Dell Inspiron 15R Screen Replacement
Was du brauchst
  1. Dell Inspiron 15R Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over and locate the battery.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 15R Screen Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 2, Bild 2 von 2
    • Place thumbs on each latch and push outwards.
    Frag FixBot
  3. Dell Inspiron 15R Screen Replacement: Schritt 3, Bild 1 von 1
    • Push and slide the battery away from you.
    Frag FixBot
  4. Dell Inspiron 15R Screen Replacement, Keyboard: Schritt 4, Bild 1 von 3 Dell Inspiron 15R Screen Replacement, Keyboard: Schritt 4, Bild 2 von 3 Dell Inspiron 15R Screen Replacement, Keyboard: Schritt 4, Bild 3 von 3
    • Locate the RAM compartment and the screw on the right hand side. Remove the cover.
    Frag FixBot
  5. Dell Inspiron 15R Screen Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 5, Bild 2 von 2
    • Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
    Frag FixBot
  6. Dell Inspiron 15R Screen Replacement: Schritt 6, Bild 1 von 1
    • Turn the device around and open it up.
    Frag FixBot
  7. Dell Inspiron 15R Screen Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 7, Bild 2 von 2
    • Using your index finger, push down on the F1 and F7 keys.
    Frag FixBot
  8. Dell Inspiron 15R Screen Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 8, Bild 2 von 2
    • Using your index finger, push down on the x icon and Home keys.
    Frag FixBot
  9. Dell Inspiron 15R Screen Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 9, Bild 3 von 3
    • Locate the keyboard lining (between the black and silver).
    • Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
    Frag FixBot
  10. Dell Inspiron 15R Screen Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 10, Bild 2 von 2
    • Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
    Frag FixBot
  11. Dell Inspiron 15R Screen Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 11, Bild 2 von 2
    • Carefully pull and turn the keyboard over.
    Frag FixBot
  12. Dell Inspiron 15R Screen Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 12, Bild 2 von 2
    • Lift the black lever.
    Frag FixBot
  13. Dell Inspiron 15R Screen Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 13, Bild 2 von 2
    • Remove the keyboard cable
    Frag FixBot
  14. Dell Inspiron 15R Screen Replacement, Hard Drive: Schritt 14, Bild 1 von 2 Dell Inspiron 15R Screen Replacement, Hard Drive: Schritt 14, Bild 2 von 2
    • Turn laptop over and remove the bottom four screw covers outlined in red.
    • Then remove the three base screws.
    Frag FixBot
  15. Dell Inspiron 15R Screen Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 15, Bild 2 von 2
    • Turn laptop over and open it. Locate and remove the five palm rest screws.
    Frag FixBot
  16. Dell Inspiron 15R Screen Replacement: Schritt 16, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 16, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 16, Bild 3 von 3
    • Locate the palm rest cables. Lift the black levers and unplug the blue cables.
    Frag FixBot
  17. Dell Inspiron 15R Screen Replacement: Schritt 17, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 17, Bild 2 von 2
    • Lift the palm rest until it snaps off.
    Frag FixBot
  18. Dell Inspiron 15R Screen Replacement: Schritt 18, Bild 1 von 2 Dell Inspiron 15R Screen Replacement: Schritt 18, Bild 2 von 2
    • Close cover and turn laptop over. Locate and remove the four hard drive screws.
    Frag FixBot
  19. Dell Inspiron 15R Screen Replacement: Schritt 19, Bild 1 von 1
    Frag FixBot
  20. Dell Inspiron 15R Screen Replacement: Schritt 20, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 20, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 20, Bild 3 von 3
    • Lift and remove the hard drive.
    Frag FixBot
  21. Dell Inspiron 15R Screen Replacement: Schritt 21, Bild 1 von 1
    • Remove the hard drive connector.
    Frag FixBot
  22. Dell Inspiron 15R Screen Replacement, Screen: Schritt 22, Bild 1 von 2 Dell Inspiron 15R Screen Replacement, Screen: Schritt 22, Bild 2 von 2
    • Locate and remove the bottom hinge screws.
    Frag FixBot
  23. Dell Inspiron 15R Screen Replacement: Schritt 23, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 23, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 23, Bild 3 von 3
    • Turn laptop over and open it. Locate and unplug the LCD Cable.
    Frag FixBot
  24. Dell Inspiron 15R Screen Replacement: Schritt 24, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 24, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 24, Bild 3 von 3
    • Unplug the black and white wires on the wireless antenna.
    Frag FixBot
  25. Dell Inspiron 15R Screen Replacement: Schritt 25, Bild 1 von 3 Dell Inspiron 15R Screen Replacement: Schritt 25, Bild 2 von 3 Dell Inspiron 15R Screen Replacement: Schritt 25, Bild 3 von 3
    • Remove the two hinge screws on both the left and right hand side.
    Frag FixBot
  26. Dell Inspiron 15R Screen Replacement: Schritt 26, Bild 1 von 1
    • Remove the screen.
    Frag FixBot
Abschluss
San Diego State, Team 2-2, Sheppard Winter 2015 Mitglied von San Diego State, Team 2-2, Sheppard Winter 2015
SDSU-SHEPPARD-W15S2G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 2,797
