Einleitung
This guide will demonstrate how to remove an old webcam and replace it.
Was du brauchst
Locate the RAM compartment and the screw on the right hand side. Remove the cover.
Locate and remove the 2.5 mm x 5 mm screw on the upper right hand side of the compartment.
Locate the keyboard lining (between the black and silver).
Place your spudger between the keyboard lining behind the F1 and F7 keys and pull up.
Place your spudger between the keyboard lining behind the x icon and Home keys and pull up.
Turn laptop over and remove the bottom four screw covers outlined in red.
Then remove the three base screws.
Locate the palm rest cables. Lift the black levers and unplug the blue cables.
Close cover and turn laptop over. Locate and remove the four hard drive screws.
Eine weitere Person hat diese Anleitung absolviert.
