Zum Hauptinhalt wechseln
Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement
Was du brauchst
  1. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: Schritt 1, Bild 1 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: Schritt 1, Bild 2 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: Schritt 1, Bild 3 von 3
    • Flip the laptop over with the bottom facing up.
    • Pull the latches away from each other to release the battery.
    • Remove the battery.
  2. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 2, Bild 2 von 2
    • Throughout this guide, be sure to keep all screws in a safe place so they do not get lost. You should also keep them organized so they do not get mixed up.
    • Remove the 4 screws in the battery compartment using a 2.0mm magnetic phillips head screwdriver.
  3. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 3, Bild 1 von 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 3, Bild 2 von 2
    • The screws do not come out of the access door. Do not try to remove them.
    • Loosen the 3 screws on the access door using the 2.0mm phillips head screwdriver.
    • Remove the access door.
  4. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 4, Bild 3 von 3
    • Remove the disk drive screw using the 2.0mm phillips head screwdriver.
    • Remove the disk drive from the laptop.
    • Remove the 2 screws under the disk drive with the 2.0mm phillips head screwdriver.
  5. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 5, Bild 2 von 2
    • Remove the 4 hard drive screws using the 2.0mm phillips head screwdriver.
    • Pull the tab to remove the hard drive from the computer.
  6. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 6, Bild 1 von 1
    • Remove the 5 bottom base screws using the 2.0mm phillips head screwdriver.
  7. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 7, Bild 3 von 3
    • Depress the keyboard latches to release the keyboard with the 2.0mm flat head screwdriver.
    • Lift the keyboard up carefully.
    • Release the two ribbon cables underneath the keyboard.
  8. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 8, Bild 2 von 2
    • Remove the 6 palm rest screws using the 2.0mm phillips head screwdriver.
    • Unplug the 3 ribbon cables.
  9. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 9, Bild 3 von 3
    • Take your time on this step and be careful to not break the plastic palm rest.
    • Separate the palm rest from the bottom base using the 2.0mm flat head screwdriver as a lever.
    • Unplug the ribbon cable underneath the palm rest.
  10. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 10, Bild 1 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 10, Bild 2 von 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: Schritt 10, Bild 3 von 3
    • Remove the 2 DC jack bracket screws with the 2.0mm phillips head screwdriver and remove the bracket.
    • Unplug and remove the old DC jack.
Abschluss
Follow these instructions in reverse order to reassemble your device.
Allen Van Den Boom
109 Reputation
1 Anleitung geschrieben
Michigan Tech, Team S3-G1, Galliah Fall 2017 Mitglied von Michigan Tech, Team S3-G1, Galliah Fall 2017
MTU-GALLIAH-F17S3G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 1,431
