Zum Hauptinhalt wechseln
Dell Inspiron 15z 5523 Hard Drive Assembly Replacement
Was du brauchst
  1. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Lifting the Hard Drive Assembly: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Lift the hard-drive assembly to disconnect it from the system board and remove the hard-drive assembly from the computer base.
  2. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Remove the Screws: Schritt 2, Bild 1 von 1
    • Remove the screws that secure the hard drive to the hard-drive bracket.
  3. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Lifting the Hard Drive: Schritt 3, Bild 1 von 2 Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Lifting the Hard Drive: Schritt 3, Bild 2 von 2
    • Lift the hard drive out of the hard-drive bracket.
  4. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Placing the Hard Drive: Schritt 4, Bild 1 von 1
    • Place the NEW hard drive into the hard-drive bracket.
  5. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Align the Screw Holes: Schritt 5, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  6. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Replace the Screws: Schritt 6, Bild 1 von 1
    • Replace the screws that secure the hard drive to the hard-drive bracket.
  7. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Placing the Hard-Drive Assembly: Schritt 7, Bild 1 von 1
    • Place the hard-drive assembly on the computer base.
  8. Dell Inspiron 15z 5523 Hard Drive Assembly Replacement, Sliding the Hard-Drive Assembly: Schritt 8, Bild 1 von 1
    • Slide the hard-drive assembly toward the back of the computer, to connect the hard-drive assembly to the connector on the system board.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 365
