Zum Hauptinhalt wechseln
Dell Inspiron 15z 5523 Memory Module Replacement
Was du brauchst
  1. Dell Inspiron 15z 5523 Memory Module Replacement, Loosen the Screw: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  2. Dell Inspiron 15z 5523 Memory Module Replacement, Lifting the Module Cover: Schritt 2, Bild 1 von 1
    • Using your fingertips, lift the memory-module cover out of the slots on the computer base.
  3. Dell Inspiron 15z 5523 Memory Module Replacement, Popping up the Memory Module: Schritt 3, Bild 1 von 1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  4. Dell Inspiron 15z 5523 Memory Module Replacement, Sliding the Memory Module: Schritt 5, Bild 1 von 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
  5. Dell Inspiron 15z 5523 Memory Module Replacement, Slide the Tabs: Schritt 6, Bild 1 von 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  6. Dell Inspiron 15z 5523 Memory Module Replacement, Tighten the Screw: Schritt 7, Bild 1 von 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Ziellinie
Terrence15
79.309 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.984 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 187
