Zum Hauptinhalt wechseln
Dell Inspiron 16 7610 Back Case Replacement
Was du brauchst
  1. Dell Inspiron 16 7610 Back Case Replacement, Back Case: Schritt 1, Bild 1 von 2 Dell Inspiron 16 7610 Back Case Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16 7610 Back Case Replacement: Schritt 2, Bild 1 von 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
Abschluss
Jerson Gomez
877 Reputation
3 Anleitungen geschrieben
Gateway, Team 1-3, Pee Spring 2023 Mitglied von Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Followed instructions. No clips broken but still cannot close the back cover. There’s a small gab in between the mouse and the cover when I close it.
Enos Nii Armah - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 24
Insgesamt: 436
