Zum Hauptinhalt wechseln
Dell Inspiron 16-7610 Battery Replacement
Was du brauchst
  1. Dell Inspiron 16-7610 Battery Replacement, Back Case: Schritt 1, Bild 1 von 2 Dell Inspiron 16-7610 Battery Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16-7610 Battery Replacement: Schritt 2, Bild 1 von 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Dell Inspiron 16-7610 Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Dell Inspiron 16-7610 Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to life the battery up and remove it from the laptop.
Abschluss
Michael Torres
145 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-3, Pee Spring 2023 Mitglied von Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 13
Letzte 30 Tage: 64
Insgesamt: 870
