Zum Hauptinhalt wechseln
Dell Inspiron 16-7610 RAM Replacement
Was du brauchst
  1. Dell Inspiron 16-7610 RAM Replacement, Back Case: Schritt 1, Bild 1 von 2 Dell Inspiron 16-7610 RAM Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16-7610 RAM Replacement: Schritt 2, Bild 1 von 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 RAM Replacement, RAM: Schritt 3, Bild 1 von 3 Dell Inspiron 16-7610 RAM Replacement, RAM: Schritt 3, Bild 2 von 3 Dell Inspiron 16-7610 RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
Abschluss
Michael Torres
145 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-3, Pee Spring 2023 Mitglied von Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 291
