Zum Hauptinhalt wechseln
Dell Inspiron 16-7610 Wi-Fi Card Replacement
Was du brauchst
  1. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: Schritt 1, Bild 1 von 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: Schritt 1, Bild 2 von 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove seven 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
  2. Dell Inspiron 16-7610 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 1 von 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 3, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  4. Dell Inspiron 16-7610 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
Abschluss
Gateway, Team 1-3, Pee Spring 2023 Mitglied von Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 134
