Zum Hauptinhalt wechseln
Dell Inspiron 17 Laptop Battery Replacement
Was du brauchst
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: Schritt 4, Bild 1 von 1
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: Schritt 5, Bild 1 von 1
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
Abschluss
17 weitere Personen haben diese Anleitung absolviert.
York University, Team 2-7, O'Regan Fall 2023 Mitglied von York University, Team 2-7, O'Regan Fall 2023
YORK-O'REGAN-F23S2G7
1 Mitglied
3 Anleitungen geschrieben
1 Kommentar zur Anleitung
Mon ordinateur ne s'allume pas malgré plusieurs tentatives
Tougouma - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 60
Letzte 30 Tage: 268
Insgesamt: 7,018
