Zum Hauptinhalt wechseln
Dell Inspiron 17 N7010 BIOS Battery Replacement
Was du brauchst
  1. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove disc drive: Schritt 1, Bild 1 von 1
    • Remove the single Philips screw securing the disc drive.
    • Pull the disc drive out.
  2. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: Schritt 2, Bild 1 von 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: Schritt 2, Bild 2 von 3 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest screws: Schritt 2, Bild 3 von 3
    • Remove the 22 M2.5x5 Philips screws securing the palmrest to the base.
    • Remove the seven remaining M2x2.5 screws securing the palmrest to the base.
    • Unscrew the two captive screws securing the RAM/HDD door to the base.
    • This must be done in order to access hidden screws under the hard drive.
    • Under the RAM/HDD door, unscrew the hard drive caddy. Remove the caddy.
    • Remove the three M2.5x5 screws from under where the hard drive was.
  3. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove keyboard: Schritt 3, Bild 1 von 1
    • Pop the four keyboard clips with a plastic spudger. As you do the first one, pry to get under the keyboard with your hand.
    • Remove the keyboard cable from the motherboard connector.
  4. Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: Schritt 4, Bild 1 von 2 Dell Inspiron 17 N7010 BIOS Battery Replacement, Remove palmrest: Schritt 4, Bild 2 von 2
    • Remove the palmrest cables from the motherboard connectors.
    • Remove the seven M2.5x5 screws securing the palmrest to the base.
    • Lift the palmrest.
  5. Dell Inspiron 17 N7010 BIOS Battery Replacement, Replace the cell: Schritt 5, Bild 1 von 1
    • Use a plastic spudger to get under the CR2032 cell and pry it out carefully.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph Sctbunio
7.242 Reputation
42 Anleitungen geschrieben
7 Kommentare
thanks for your help!!!
E P - Antwort
I’m happy that my guide helped you!
Joseph Sctbunio -
Lot of screws, wouldn’t even tried this without these instruction.
Thank you.
d223e
Don Endress - Antwort
Thanks for the instructions. Computer starts up great now.
jkleinjans - Antwort
doresc sa comand pentru Dell Inspiron 17 N7010 BIOS Baterie. 1 bucata. cum se procedeaza?
Florentin Manolea - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 27
Letzte 30 Tage: 129
Insgesamt: 17,352
