Einleitung
Malfunctioning keys or a completely broken keyboard can render a laptop useless to the user. This guide will show the steps to replace the keyboard of this device.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard. After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Once the keyboard is lifted, locate  the release tab. Using a plastic opening tool or your finger,  lift the tab so that it opens .
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kevin Prairie
433 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
3 Mitglieder
7 Anleitungen geschrieben
Wow that was easy! Thanks :D
Isaac Pettis - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 79
