Zum Hauptinhalt wechseln
Dell Inspiron 17-3721 Optical Drive Replacement
Was du brauchst
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: Schritt 1, Bild 1 von 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-3721 Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 1 von 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 2 von 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: Schritt 3, Bild 3 von 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 17-3721 Optical Drive Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 17-3721 Optical Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kevin Prairie
445 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S5-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G3, Peak Spring 2018
UMASSD-PEAK-S18S5G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 300
