Zum Hauptinhalt wechseln
Dell Inspiron 17-5748 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 17-5748 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down.
    • Locate the battery lock latches.
  2. Dell Inspiron 17-5748 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Slide both lock latches to the unlocked position.
  3. Dell Inspiron 17-5748 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Lift the battery up and out of the laptop battery socket.
  4. Dell Inspiron 17-5748 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 1
    • Open the laptop and locate the keyboard.
  5. Dell Inspiron 17-5748 Keyboard Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 17-5748 Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Locate the 5 keyboard tabs at the side of the keyboard closest to the screen.
    • Using a metal spudger, gently pry the keyboard tabs inwards until they loosened. You should hear a click.
  6. Dell Inspiron 17-5748 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17-5748 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Do not remove the keyboard completely. The ribbon cable underneath, attaching it to the motherboard, must still be detached.
    • Lift the keyboard partially and flip it over.
  7. Dell Inspiron 17-5748 Keyboard Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 17-5748 Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Detach the ribbon cable from the motherboard by tilting up the black clip, releasing the cable.
    • Gently detach the cable and the keyboard from the laptop.
Abschluss
Washington State, Team S2-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S2-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S2G2
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 643
