Zum Hauptinhalt wechseln
Dell Inspiron 17-5749 Palm Rest Replacement
Was du brauchst
  1. Dell Inspiron 17-5749 Palm Rest Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Inspiron 17-5749 Palm Rest Replacement, Battery: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 2, Bild 2 von 2
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Palm Rest Replacement, Back Cover: Schritt 3, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Back Cover: Schritt 3, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Back Cover: Schritt 3, Bild 3 von 3
    • Remove the two 5.5mm screws that secure the base cover to the computer's base.
    • Using the plastic opening tool, carefully pry open the base cover starting from the center.
    • Lift the base cover upwards to remove and set it aside.
  4. Dell Inspiron 17-5749 Palm Rest Replacement, Optical Drive: Schritt 4, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Optical Drive: Schritt 4, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Optical Drive: Schritt 4, Bild 3 von 3
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  5. Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 5, Bild 3 von 3
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
  6. Dell Inspiron 17-5749 Palm Rest Replacement, Hard Drive: Schritt 6, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Hard Drive: Schritt 6, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Hard Drive: Schritt 6, Bild 3 von 3
    • Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
    • Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
    • Lift the hard-drive assembly off the computer base
  7. Dell Inspiron 17-5749 Palm Rest Replacement, Keyboard: Schritt 7, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Keyboard: Schritt 7, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement, Keyboard: Schritt 7, Bild 3 von 3
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  8. Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 8, Bild 1 von 1
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
  9. Dell Inspiron 17-5749 Palm Rest Replacement, Palm Rest: Schritt 9, Bild 1 von 2 Dell Inspiron 17-5749 Palm Rest Replacement, Palm Rest: Schritt 9, Bild 2 von 2
    • Remove the (5) 5.5mm screws that secure the palm rest to the system board.
    • Close the display and turn the computer over.
    • Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
  10. Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 10, Bild 1 von 3 Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 10, Bild 2 von 3 Dell Inspiron 17-5749 Palm Rest Replacement: Schritt 10, Bild 3 von 3
    • Turn the computer over and open the display as far as possible.
    • Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
    • Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
    • Lift the palm rest away from the display assembly.
Abschluss
Christopher Tran
1.162 Reputation
12 Anleitungen geschrieben
Washington State, Team S1-G2, Lobnitz Spring 2018 Mitglied von Washington State, Team S1-G2, Lobnitz Spring 2018
WSU-LOBNITZ-S18S1G2
6 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 230
