Einleitung
This guide will take you through the steps to replace your RAM. Make sure you are working in an un-carpeted area so you will not shock your laptop components. Before starting make sure to completely turn off your laptop and unplug it from any power source.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Switch each of the battery latches to the "unlocked" position.
Pull battery upwards by the tab to remove from the laptop.
Remove the two 5.5mm screws that secure the base cover to the computer's base.
Using the plastic opening tool, carefully pry open the base cover starting from the center.
Lift the base cover upwards to remove and set it aside.
Using your fingertips, spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
Slide the memory module away from the memory-module slot.
