Einleitung
This guide will allow you to replace a damaged/faulty hard drive for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement
Was du brauchst
Find the battery release latch on the bottom side of the computer.
Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
Turn over your laptop and locate the two screws which secure the base cover.
Use a Phillips #0 screwdriver to unscrew the 8mm screws which secure the base cover.
Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
Now with the base cover removed, you may lift it off of the laptop and continue.
Locate the hard drive cable, and disconnect it from the laptop by lifting the latch which secures the cable.
Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
Remove the interposer by grabbing the black portion of the assembly, and pulling it away from the hard drive.
Use a Phillips #0 screwdriver to remove the four 4mm screws on either side of the hard drive assembly.
Safely remove the hard drive assembly from the hard drive to complete the process.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
My question is, the hard drive is this a 7mm, 12mm or 15mm drive bay? I want to put a 4tb in my laptop but those are 15mm size and I can’t find what the size limit of the bay is.
I want to put a 4tb harddrive in my laptop.
Those only come in 15mm.
will this drive bay hold 15mm sized drives?
