Zum Hauptinhalt wechseln
Dell Inspiron 17-5755 Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: Schritt 4, Bild 1 von 2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 17-5755 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S6-G1, Lacy Spring 2017 Mitglied von USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 715
