Zum Hauptinhalt wechseln
Dell Inspiron 17-7737 Battery Replacement
Was du brauchst
  1. Dell Inspiron 17-7737 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Battery Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 17-7737 Battery Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 17-7737 Battery Replacement: Schritt 2, Bild 3 von 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Battery Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 17-7737 Battery Replacement: Schritt 4, Bild 2 von 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
Abschluss
Mark Batista
457 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 218
