Zum Hauptinhalt wechseln
Dell Inspiron 17-7737 Hard Disk Drive Replacement
Was du brauchst
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 2, Bild 3 von 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 5, Bild 1 von 1
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 1
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: Schritt 9, Bild 1 von 1
    • Using the pull tab, lift the hard drive out of the cage.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mark Batista
457 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 260
