Zum Hauptinhalt wechseln
Dell Inspiron 17-7737 RAM Replacement
Was du brauchst
  1. Dell Inspiron 17-7737 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 RAM Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 17-7737 RAM Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 17-7737 RAM Replacement: Schritt 2, Bild 3 von 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 RAM Replacement: Schritt 3, Bild 1 von 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 RAM Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 17-7737 RAM Replacement: Schritt 4, Bild 2 von 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 RAM Replacement, RAM: Schritt 5, Bild 1 von 3 Dell Inspiron 17-7737 RAM Replacement, RAM: Schritt 5, Bild 2 von 3 Dell Inspiron 17-7737 RAM Replacement, RAM: Schritt 5, Bild 3 von 3
    • Pry the memory module's cover off of the computer's base using an opening tool.
  6. Dell Inspiron 17-7737 RAM Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 17-7737 RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove the 1st stick of memory by pushing the two lock pins to the side and pulling the stick out of the base.
  7. Dell Inspiron 17-7737 RAM Replacement: Schritt 7, Bild 1 von 2 Dell Inspiron 17-7737 RAM Replacement: Schritt 7, Bild 2 von 2
    • Remove the second RAM stick in the same fashion.
Abschluss
Mark Batista
457 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Mitglied von UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 52
